Stroking the M113K
I've been over this plan fairly thoroughly and while It's not easy, it's definitely not impossible. I'm always up for fun and interesting projects , get a hold of me if you're serious about building one. I can either build it or offer up some useful advice.
Ive stroked a few motors this way. It's been awhile but, Im almost certain the machine shop I used welded material then offset grinded the crank to increase stroke.
I think money spent on CNC porting the heads and radical camshafts specs will yield much better results, easier and less "custom" work. Because even if you are successful at stroking the motor. Your cams will be too small and the motor will be running out of air. So by increasing airflow at the cylinder head (where power is created) would be the optimum choice.
Vaeth 5.8L conversion is a stroker kit so it's definitely doable on our engine. May require a new crankshaft which is mega money so if we could do away with our existing crankshaft I'd be up for it. 200-300cc with a stroker kit, 100cc with a 1mm overbore and you're getting close to 6L.
- 5.8: n/a engine with 1mm more stroke and 2mm bigger bore diameter
- 5.7K: supercharged n/a engine with 1mm more stroke and 1 mm bigger bore
- 6.1: n/a engine with 5mm more stroke and and 2,5mm bigger bore
Väth also made a stroked M113 engine:
- V58K: M113ML-Block with 3mm more stroke and 1mm more bore (620HP)
Brabus and Väth used specially made crankshafts. None of them grinded the OEM crankshaft !
How about a vacuum pump. They are always good for 15-30 hp depending on the engine . I did a few Electric pump set ups like the corvette but never got to dyno it. That would be very easy as I am poking around right now ob what to do. On my Mustang I had the pcv system with one way check valves. As soon as the engine made 3 lbs of boost ,the pump would turn on. So the factory system was still intact and the pump was an add on.
