Found an oil leak
Found an oil leak
Looks like it's coming from the top of the trans housing on the passenger side. Rear main seal?
If it were a rear main seal, the whole bellhousing would have to fill up before it started leaking out of the top
To be honest, other that the crankshaft position sensor on the driver side I have no idea how you could get a leak on the top of the bell with this engine
I did notice some years back that the trans fluid MB Sugar Land put in my car was a similar color as oil. If your car has been serviced at the dealer and they refilled the trans through the dipstick hole and got sloppy, that could be it
pull that bell housing bolt out and see if the threads are covered in oil as well. it could be a porous block. if it is then clean up the threads in the hole and on the bolt and put on some purple loctite.
^^Curious as to how the FPR will allow oil leak?
