Is the p030 perf. pkg onl for e63?
Old Mar 5, 2015 | 10:13 AM
vikingdiesel's Avatar
15 S63, 18 Ram 2500 Cummins
I just recently found out about this package and can't really find much info on it. Was this an option only on e63 models?
Old Mar 5, 2015 | 11:21 AM
cdd's Avatar
cdd
Yes, only on e63
LSD
Stiffer suspension
2 piece wheels
Alcantara steering wheel
Higher delimited speed
Old Mar 5, 2015 | 12:19 PM
mightar's Avatar
Veteran: Navy
V60 Polestar, Veloster N 6MT
And only for the sedan - not the wagon (grrrr...).
To be honest though, I think the only really compelling thing in the package is the lsd. I have no idea how the suspension differs between the P30 and the regular stock AMG suspension. The other bits are pretty much cosmetic.
Old Mar 5, 2015 | 12:50 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Why in the heck would it have not been available for the wagon?
Old Mar 6, 2015 | 09:10 AM
1badassbenz's Avatar
Mercedes
I do know that the following cars were offered with P030 Package. I myself owned a 2008 E63 with the P030 package and there was a noticable difference.
E63
CLS 55
CLS63
SL55
SLK55
1. Limited Slip Locking Diff
2. 2 Piece Wheels
3. Alcantra/Leather Steering Wheel
4. Increased Speed Limiter
5. Nurburgring Tuned Suspension ( control arms/stabalizers & slightly lower stance)
6. Bigger Brakes
7. Higher Speed Rated Tires
Old Mar 6, 2015 | 02:19 PM
cdd's Avatar
cdd
E63
CLS 55
CLS63
SL55
SLK55
2. 2 Piece Wheels
6. Bigger Brakes
Well, crap. If I had known my car was tuned for the Nurburgring, then I would have taken it there!
I don't think #6 was part of the E63 P030 in the US, at least...and I have no idea on #7.
Old Mar 6, 2015 | 02:20 PM
Zed82's Avatar
E500 -03
Well. It depends. Europe market had a P030 package for the E55 but it´s rare as hens teeth.
I have one and it´s equipped with LSD, alcantara steering wheel, speed limit 300km/h, roll valve that cuts the fuel and power.
Old Mar 6, 2015 | 05:32 PM
e500slr's Avatar
2011 E63, 2013 CLS63
Originally Posted by cdd
Yes, only on e63
LSD
Stiffer suspension
2 piece wheels
The 2 piece wheels on the W211 E63 are **** looking. The stock 18 inch ones are much better looking and suited to the car.
The factory LSD isn't as good as an aftermarket one and aftermarket ones aren't expensive.
Delimited higher speed isn't completely delimited. You can easily tune and delimit it yourself and it will be totally unlimited (only by engine power of course )
Stiffer Airmatic might be nice but I haven't driven one so I don't know how different it is.
If the actual control arm, suspension setup is different then yes it would be worth it as would bigger brakes.
Old Mar 6, 2015 | 05:51 PM
HeissRod's Avatar
Agreed. I'm not a fan.
Old May 12, 2015 | 11:46 PM
alexxE63's Avatar
W211 E63
does it say anywhere on the car if it is a p030?
Old May 12, 2015 | 11:48 PM
Mercedes
No it doesn't. Unless you have the factory window sticker.
Old May 13, 2015 | 10:40 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
The tire sticker in the door jamb will indicate that it was equipped with the bigger wheels/tires if it left the factory as a P030 car
Old May 13, 2015 | 10:48 AM
Mercedes
P030 2 piece wheels are still 18" wheels and same tire size as regular E63
Old May 13, 2015 | 11:35 AM
Oops! Thanks for the correction, the SL and CLS get bigger/wider wheels with the 030 pkg.
Old May 13, 2015 | 02:05 PM
Denroll's Avatar
'06 E55
E63
CLS 55
CLS63
SL55
SLK55
There's also a difference in the rear end gearing on these. I don't remember which ones are which, but some are 2.82 and some are 3.06. If you plan on swapping one of these out into your non-P030 equipped car (2.6-something on the E55), you will need the TCU to be updated.
Old May 13, 2015 | 02:55 PM
I'm not that familiar with the other 030 cars but the CLS55 definitely still has the same ratio as the regular CLS55/E55
Old May 15, 2015 | 03:30 PM
JoeNobody's Avatar
Mercedes
Yeah I'm pretty sure all P030's have the same gear ratio as non P030.
Difference in rear gear ratio is between different models (E55 is 2.65, E63 & Sl55 are 2.82, Sl63 is 3.06, etc.)
