w211 Wheel fitment experts help!
Wheel fitment experts.... I need your help..
ok so I have a w211 2004 e55 amg stock height / stock fenders currently (would probably star lower at some point after I find wheels) I am looking at 2 sets of wheels with the following specs One set is: F 20x8.5 +35 R 20.10.5 +35 the other set is: F 20x9 +30 R 20x10.5 +35 Will either of these fit the car? Without modifications? What size tires would not rub and be correct for this setup if they do fit? |
LM7 ran the following specs found in this thread....
F 20x9 +25 R 20x10.5 +45 (After he shaved Vossen's +42 spec) Comparing your rear 20x10.5 +35 means your rear wheels will be 10mm further out than his, which are already pretty far out. I doubt they will fit, especially after lowering. Play around with this offset calculator to compare other wheel specs you find in this forum http://www.1010tires.com/Tools/Wheel-Offset-Calculator# |
This car has got to be one of the bigger pains in the ass to find wheels for that I've ever had. From the Dust caps in the hubs, to the brakes clearance, to the limited offsets in this bolt pattern.
wheels
I have 20" 10.5 with +42 and the fit is perfect and cant stick out any further. I am lowered with links.
Originally Posted by Cashville
(Post 6371863)
+32 I think. I only have half the number showing. Front tires 245/30 20 and the rear is 285/25/20
I'm running 20x9 +30 front (255/30/20 Michelin super sport)
20x10.5 + 35 rear (295/25/20 Michelin super sport) Please note the car is lowered on links. |
Sosa no rubbing? 10.5 +35 with 295's sounds pretty aggressive.
1 Attachment(s)
Setup: 20x10.5 +42 (Hankook V12 295/25/20)
Lowered w/ Star Zero Rub, Basically perfect fitment and no issues. Car road great as well despite the 25 Series in the rear. Attachment 390159 |
Originally Posted by skunkd
(Post 6394285)
Did you have to roll your fenders? Or anything to that nature. Also what tire size are you running?
Originally Posted by Sosa
(Post 6373803)
Yeah had to roll and slight flare the rear. I used a fender roller kit. Since then I have been able to get a 20x11 35et with a 295/25/20.
