I have searched and cant find exact answer
can someone please tell me the part number for the fuel filter for a 2006 CLS55. This should be a simple find. I'm just changing it for maintenance. i was told its the left side. Im trying to order it and have ordered it several times getting the wrong part.
PLATINUM SPONSOR
I have the pumps/filter assembly in boxes and with part numbers at my office. If you need any other info, let me know before we ship them out.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Well i ordered the right part im sure 211-470-49-94 which I'm pretty sure is drivers side filter. they have that on packing order but the part is passenger side double pumps.
