Shortlist of bluetooth options needed
Old Apr 11, 2015 | 09:24 PM
Hotsauce55's Avatar
2005 E55
Need your recommendations on what you currently use or would use. My car doesnt have a phone cradle or anything in the center console. I am looking for the following features:
1. Stream music from android phone via bluetooth
2. Control songs from either steering wheel or comand unit. Must be able to see the artist and title
3. Handsfree phone calls via car speakers
4. Top quality sound
5. A nice to have would be reading songs from a usb stick instead of phone.
6. No butchering wires
Whats everyone here using and are you pleased?
Old Apr 11, 2015 | 10:42 PM
cetialpha5's Avatar
Do you have the ipod cable? My guess is that you don't, but I think you can just buy the ipod cable and connect it to your comand in the back. I think that's the only way to get #2. Unfortunately, it's only an ipod touch or an iphone. I use spotify so I was able to get a 4th gen ipod touch (cowboom.com sells used ones cheap) which still had the 30 pin connector and sync it with my spotify playlists.
It's somewhat annoying how you can buy a garmin GPS with bluetooth in it for less than $100, but getting it from the manufacturer costs hundreds, probably closer to $1000.
Old Apr 12, 2015 | 08:36 AM
Hotsauce55's Avatar
2005 E55
I have the ipod jack in glovebox i think no cable though.
Old Apr 12, 2015 | 11:23 AM
cetialpha5's Avatar
It's probably the aux jack, the ipod cable would be a 30 pin connector. If you just have a jack, then you don't have the ipod cable.
I'm not sure it would be worth it for you to wire the car for bluetooth if it's not pre-wired for bluetooth. There's some module you'd have to add to the Comand system, then you'd have to add that connector in the glove box and then add the bluetooth puck.
The other way is to go with an aftermarket comand unit, they're aftermarket android systems that may do everything you want, however they don't seem to sell too many of them so if you run into problems, you're not going to find too much help.
Old Apr 12, 2015 | 03:44 PM
Hotsauce55's Avatar
2005 E55
How can i tell for sure if i am pre wired for BT?
Old Apr 12, 2015 | 03:58 PM
cetialpha5's Avatar
Post the vin number, there should be some option code for bluetooth.
Old Apr 12, 2015 | 04:04 PM
Hotsauce55's Avatar
2005 E55
WDBUF76J25A624603
Old Apr 12, 2015 | 05:09 PM
cetialpha5's Avatar
Originally Posted by Hotsauce55
Here's the datacard from epcnet. Doesn't look like you have a feature code for it.
Sales designation: E 55 AMG
Order number: 0 5 706 19040
Delivery date: 21 06 2004
Paint code 1: 359U TANZANITE BLUE METALLIC FINISH
Equipment: 251A LEATHER - BLACK/ANTHRACITE
Engine no.: 113990 60 032490
Transmission: 722643 05 446033
Engine
Major assembly variant: A 113 010 25 02
212B OP. INSTRUCT. AND MAINT. BOOKLET-ENGL. FOR USA/CAN
213 SPEED-SENSITIVE POWER STEERING/VARIO STEERING
21N STEUERCODE WERK SINDELFINGEN/GRAZ
220 PARKTRONIC SYSTEM (PTS)
221B SIGN COOLANT/REFUELING - ENGLISH
232 GARAGE DOOR OPENER WITH 284 - 390 MHZ FREQUENCY
242 FRONT SEAT RH ELECTRIC ADJUSTABLE WITH MEMORY
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
250A LEATHER
264 LICENSE PLATE ATTACHMENT AMERICA
265 LINES-NO.PLATE DISCONTINUED
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
284B AIRBAG LABEL - ENGLISH FOR USA
28N STEUERCODE WERK SINDELFINGEN/GRAZ
293 SIDEBAG IN REAR LEFT AND RIGHT
309 CUP HOLDER
359 LOW COST TELEAID USA
401 FRONT SEAT CLIMATE CONTROL
404 MULTI-CONTOUR SEAT, FRONT LEFT
405 MULTI-CONTOUR SEAT, FRONT RIGHT
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
423 5-SPEED AUTOMATIC TRANSMISSION
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
475 TIRE PRESSURE MONITOR (TPM) HIGH LINE/MID LINE
489 AIRMATIC DUAL CONTROL / AIR SUSPENSION SEMI-ACTIVE
494 U.S. VERSION
524 PRODUCT PROT. F.PAINT - TRANSPORT VEH.PRESERVATION
528 COMAND DVD PLUS (WITHOUT NAVIGATION)
543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE-
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
573 CHILD SEAT MOUNTING, ISOFIX IN REAR
581 AUTOMATIC CLIMATE CONTROL
634 DELETION - FIRST AID KIT
636 DELETION - WARNING TRIANGLE
668 PRODUCT PROT.F.TRANSPORT VEH. W/ TIE-DOWN HOOKS
669 SPARE WHEEL / FOLDING WHEEL
673 HIGH-CAPACITY BATTERY
706L UNITED STATES (USA)
763 RADIO REMOTE CONTROL W/ PANIC SWITCH (315 MHZ)
772 AMG STYLING PACKAGE-FRONT SPOILER, SIDE SKIRT
7XXL NORTH AND SOUTH AMERICA
805 YEAR OF MODIFICATION
810 SOUND SYSTEM
819 CD CHANGER
875 HEATED SCREEN WASH SYSTEM
910 DYNAMO WITH HIGHER CAPACITY (FFO)
915 FUEL TANK WITH LARGER CAPACITY
919 AIRCON COOLING POWER PACKAGE
954 EQUIPMENT PACKAGE FOR AVANTGARDE VEHICLES
986 IDENTIFICATION NUMBER (VIN-NO.)
989 IDENTIFICATION LABEL UNDER WINDSHIELD
M001 ENGINES WITH SUPERCHARGER
M113 V8-GASOLINE ENGINE M113
M55 CAPACITY 5,5 LITRE
Y88 ORION GRAY ALCANTARA HEADLINER
Old Apr 12, 2015 | 05:17 PM
Hotsauce55's Avatar
2005 E55
Thanks for the help, appreciate it. What about something like this?
Old Apr 12, 2015 | 06:51 PM
ATLVR6's Avatar
SC'd GTI VR6 05 E55
Subscribing to this thread because I'm in the same boat.
Old Apr 13, 2015 | 05:27 AM
StuttgartAMG's Avatar
E55 AMG (W211)
Dension Gateway 500BT!?
Old Apr 14, 2015 | 09:35 AM
ATLVR6's Avatar
SC'd GTI VR6 05 E55
Has anyone used this unit? If so, what are their pros/cons in their opinion?
Old Apr 14, 2015 | 10:02 AM
Hotsauce55's Avatar
2005 E55
Looks like a nice unit that has everything $500 USD. I watched an install video & a few wires have to be hacked, not ideal but not much choice unless you go with the Android 4.2.2 $500 USD or Dynavin N6 MBE $1,100 USD
Old Apr 14, 2015 | 11:25 AM
ATLVR6's Avatar
SC'd GTI VR6 05 E55
The Dynavin looks plug N play. Gonna research both.
Old Apr 14, 2015 | 02:51 PM
Denroll's Avatar
'06 E55
That Android 4.2.2 looks sweet. How long has that "New" ribbon been on there? If that could take GPS from the factory antenna, that would be quite legit. Possibly even too legit to quit.
Old Apr 14, 2015 | 11:23 PM
Worloc918's Avatar
E55 AMG
Subscribing, I have been missing my app radio in my other car.....
Old Apr 15, 2015 | 08:21 AM
Hotsauce55's Avatar
2005 E55
I think the Dynavin requires you to bypass the fiber optic connections?
Old Apr 15, 2015 | 10:25 AM
erupert66's Avatar
'05 SL55
I have the mObridge unit. Just upgraded from the one that was in the car when I bought it (AB2010) to the M2.Pro. Does everything you mentioned and is FULLY integrated. Uses the Fiber Optic BUS that is in all of the German Cars.
bought mine from this guy - discounted it.
BILL PERKOSKI
CUSTOM CELLULAR
20 CORPORATE PARK STE 240
IRVINE CA 92606-3117
Old Apr 15, 2015 | 02:52 PM
ATLVR6's Avatar
SC'd GTI VR6 05 E55
BILL PERKOSKI
CUSTOM CELLULAR
Do you have any pics of the unit? Pics or videos of the install? Can you give us a run down of the unit's functionality? BT (phone/streaming music), iPod, Navi, DVD, sound quality, ease of use, initial loading times, etc....any information that would help folks to make an informed decision on whether or not to buy.
Thanks in advance for the info!
Patrick.
Old Apr 15, 2015 | 03:22 PM
mkiv_tdi's Avatar
Jetta TDI [Daily] , Audi A8L [Sold], '12 STI [Sold], '06 E55 [Sold], '05 S500, '15 GLA250
Patrick.
+1
Old Apr 16, 2015 | 12:22 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
if you have a factory HK Stereo and want OEM functionality as described you'll have to do what I did. Install OEM iPod Interface which replaces your Aux line input located in your glove box. Then purchase a ViseeO Tune2Air wma1000. This only supports track name listing and music library reading if you have an apple product. Now then if you'd like to support audio calling you'd need the OEM or aftermarket version of the bluetooth telephone puck.
then there is denson or parrott integration kits.
I had a bluetooth puck already, and wished I just went with what I did with my Audi per information from other mbworld thread. Install an aftermarket bluetooth aux input that supports music and calling. Also supports bluetooth 4.0 and aptx for higher quality audio.
Amazon.com : TaoTronics TT-BR03 Bluetooth 4.0 Receiver Hands-Free Car Kit (Supports aptX, Stereo Music, Built-in Mic, 33 ft Range, 2.1A USB Charger) : Electronics Amazon.com : TaoTronics TT-BR03 Bluetooth 4.0 Receiver Hands-Free Car Kit (Supports aptX, Stereo Music, Built-in Mic, 33 ft Range, 2.1A USB Charger) : Electronics
$30 dollars vs $180+$90 is quite a huge price difference.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Apr 18, 2015 | 07:05 PM
erupert66's Avatar
'05 SL55
Sorry for the delay. I don't have pics of the install. However, there are a couple of references on YouTube.
Here's a demo of the functionality of the telephone
Here's the install for the older AB2010 which I took out of the car -
(it's abbreviated a bit, they say if you buy from them you get the complete video.
Here's the data sheet and other info from the manufacturers page -
http://www.mobridge.us/products/m2pro-most
Old Apr 20, 2015 | 04:13 PM
Rob CL's Avatar
E55 AMG | Buell Lightning XB12
Though it's a bit less complex, but certainly a breeze to install... I ordered this product from eBay:
http://www.ebay.com/itm/A2DP-Bluetoo...-/171533477812
On a full charge, the unit has gone as long as 6-hours of continuous streaming. I haven't been on trips longer than that since purchasing, yet.
The unit has great quality, and doesn't take long to charge.
One issue I've noticed, is that it states there's phone support, though I believe it accomplishes this through a microphone-capable headphone jack, versus a built-in mic, or phone mic. Suffice it to say, I've not been able to use the phone function.
Instead, I just disabled the phone audio profile on my phone. This way, when the phone rings, the streaming stops, and I can answer by hand, or another connected Bluetooth device.
