Hi all
Installing a water / methanol injection kit tomorrow, and I need to tap into the manifold after the charger to get boost pressure. It seems as though the MAP sensor is bolted straight to the inlet so cannot be teed into.
If I tee into the secondary air valve vacuum supply lines (131), will I get only manifold vacuum, or can I measure boost pressure from there also?
That's what I thought, Thanks.
