need advice on possible bad Sam
Sunday I took the car for a couple hour drive to a local track for a show, everything was working fine on the way home the car shut off while I was driving at about 60 it turned right back on before I could do anything. Did this again about 10 minutes later then was fine. When I went to start the car this morning I got gear selector p or n error , display malfunction, check coolant level, all of the headlights on the passenger side of the car are out, and the push to start option would not work. Wondering if any one has any incite into what this might be an indy tried to connect with the front Sam a while back and couldn't connect with it so that is where I'm basing my thought that it is a failed Sam unit off of any advice would be appreciated thanks
