E63 Centric Rotors
E55 - pn: 128.35068
E63 - pn: 127.35103
The only drawback... the E63 rotors are much more expensive. Somewhere around $1000 each from the dealer.
If you decide that you want two-piece rotors, check out GiroDisc.com in addition to Centric. They make the most affordable (to the best of my knowledge), and best looking two-piece rotor for W211 AMG applications.
I used the stoptech branded (centric) street performance pads for $100 bucks same thing they are fine. Bed them in hard with 10 hard stops and by the tenth stop they are really beginning to slow the car significantly faster.
The coefficient of friction is variable with temp and goes up with it and they are meant to be good to 700deg or so.
Again for the money these are hard to beat. Should be fine on track days aswell as long as your not crazy about it. My 10 stops were from 90mph-0 and the friction only noticeably changed on the 10th. Thats 10 one after the other and we all know this car can do that really quickly so I really doubt many tracks would be that harsh on them.
Also semi-rebuilt the front calipers seals and dust seals again from centric all seemed to fit fine and quality seems fine. Brakes work all good. Dirt cheap.
