Fair price for tranny fluid change?
Looking to change the fluid/filter in the tranny and am getting numbers from $399-$450 to do the job. Seems high to me. What are you guys paying?
Received 1,495 Likes
I believe you can use Shell ATF 134. You can get it from a local shell distributor for about $60-$70 for a case of 12 quarts.
https://www.shell.us/products-servic...r-locator.html
2020 E 300 Coupe and 2019 GLS 400
Guys, in the US you're lucky!
I'm getting raped at the North. $800 CAD for Transmission service + trans mount.
We have few experienced (Mercedes) shops here, so we don't have many choices.
Try finding an indy. I think you just need to go to the dealer if it needs star diagnostic, but a fluid change and mount is pretty basic and an independent mechanic should be able to do it. There are several DIY threads around of it getting done for just the cost of the filter and fluid.
I just got a quote from a local indy:
Transmission service is $300, Transmission filter, Pan Gasket, 13 pole connector and 5-6 qts of MB transmission fluid.
How does that sound?
SPONSOR
This DIY Tech Article is relevant to your vehicle. Will save you a lot and just takes a little bit of your time.
-Luccia
-Luccia
2006 S65 AMG V12BT
