w211 please help
w211 please help
Dear brothers. im Kosala from sri lanka
i have W211 E240 2004 model
car has done only 70000km. well maintained and in its original condition
But brothers, from the first day i brought the car i had problems only.
1. first i found some mixture came out form the cooling system coolant tank, like milk shake
when i check the oil level with oil gauge i found gear box oil also same color. So i updated the radiator with BEHR HELLA radiator. gear box removed and cleaned. installed the repair kit. now gear box ok. then flush the cooling system. But still i noticed heavy oil amount is coming out from the coolant tank. so i close the heater core temporary. (most of the time when we flush cooling system hard to flush heater core ). but still the same (after 1000km from the rapair still heavy amount of oil is coming out )
today im going to change oil cooler
is there any other place which can mix oil with water?
(im my case gear oil + engine oil + coolent mixed in same time )
2. SBC unit have a error " service break visit work shop"
when i connect computer via OBD 2 oprt here is the computer reading - check operating time of component A7/3 (SBC hydraulic Unit )
As i know after 300000 breaks attempts its occur as a safety matter
can i reset it using this tool -
http://www.aliexpress.com/item/Fast-...421674560.html
please help me bro.....
****And i will give u one information. I had a issue with one of my door lock, when i lock it it jumping up and down. i successfully repair it by only spending $10. if some one want to have information about it please leave a message
