Front SAM - where does this go?
So some idiot decided it would be a good idea to jump some wires when the airmatic was acting up.
after he jumped a wire the car is now acting funny and will not start. There is no communication with the shifter, and it's locked in park unless I manually unlock it.
I haven't been able to speak to the guy but nonetheless I need to fix this issue.
I suspect the wire he jump was the one in the picture, it looks as if it goes to the airmatic compressor.
After he jumped that wire is when the at stopped running (everything generally seems to work, but it won't crank at all).
So my question is, if it's from that, what could have been damaged? Only th front SAM?
In the picture I am referring to the two thicker wires in the back that plug into the SAM.
It's hard to tell in the pic but it looks like the airmatic relay is missing (upper right in that white plastic cage). Unless it's a black relay. But I only saw them in green.
Part number 0025427619
