higher temps after heat exchanger and tank.
That sounds about right, 15-20F above ambient while cruising. I have the same flow routing as Denroll, as I want iced down fluid to hit the intercooler first then thru the HE after the IC then back to the tank to hit the ice again.
Glad you found the issue, you might want to flush it again in a few weeks just to get any stragglers.
99 ford lightning
yea that's a good Idea. I would say my temps have dropped 10-15 deg now comparing to old set up and the main thing now is the car cools back down after stepping on it where the other set up once warmed up it could be as much as 33 deg over ambient.
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
tried it several ways but my stock set up with cobra tank seem to work best Im not even sure how we have it now I know its how it was on the normal spil with tank. My temps are even sometimes 50 deg above ambient when crusing takes for ever to calm down now because they actually go up after I get out of the gas and then cruise they will rise for a while. all this is coming off the car next week I hope to go back to my other set up. I logged two other e55's one has no split and it was way cooler then my car.
99 ford lightning
no drain valves on tank. cruising temps yesterday after start up were 6-7 deg over ambient it was 70deg out. after 15 min drive letting it sit for a half hour they were about 9-12 deg over ambient even after stepping on it.
#32
I switched to straight water for the summer and temps are about the same as yours now, between 8-15 over ambient. Amazing how much better water is at transferring heat than anti-freeze. You may want to consider adding a drain to the tank, it really helps if you take it to the track.
#35
The tank I purchased from Dad's had a fitting in it so I could attach a drain valve. Valve screws into fitting then has a 90* tube that exits the floor pan in the spare tire well. I have enough room to shove a milk jug underneath and empty the anti-freeze into it then dump into buckets. Or just attach a hose to it and run to a receptacle.
