Caliper bleed
Should I do a Star "brake bleed" or shut the system off and do a traditional pressure bleed from the master with a pressure pump? Thanks
I tried bleeding with my Star and it used so much damn fluid, that the next time I did it, I used just the Motive pressure on the res and a MAC vacuum on the bleeder. Worked really well.
Thanks for any help.
Do you have any lights on...esp, brake light and red STOP light on cluster?
Yes when I redid mine I was at the drivers front and could hear the passenger front caliper clamping on and off so it was trying to do the wrong side even though I was following what the screen was telling me. From there it went down hill. You have know idea how pissed I am because I might miss a great opportunity to make some passes at a small airport and now this crap because I had to have stainless lines!!!!LOL
The warnings on the cluster come on every time I connect with star. I brought this on myself trying to have fresh fluid in there for some 1/2 mile air strip runs ending of this month.
One more thing I just found out....my wife who was helping me said that the "SBC voltage" "words" kept showing on the screen. I wonder if that threw a wrench into it. I had the charger on it but I guess it couldn't keep up..... but the pump did run ok. Who knows.
Where the hell is the pressure sensor? Could there be air near it and it will not read pressure.
I am going to bleed the system with a pressure bleeder and see what I get but my bleeder is leaking so a new one is on the way.
Anyone have some ideas? Again all I did was put on two front brake lines and all was fine before hand. Also there is only 172,000 actuations on the SBC.
On a side note, my second flush with SBC went through and now the pedal feels as it should.
