Change rear subframe bushes, hard to do???
Old May 28, 2015 | 11:07 AM
E55GHi5's Avatar
E55 W211
Hello,
my rear subframe bushes (front of the rear axle) are dead.
My mechanical skills are good, but i want to know how difficult it is, to change this bushed.
Anyone done this before?
So a lift and good tools are no problem...
My car has the airmatic suspension and i don´t know exacly what i need to remove to loose the rear axle that i can change the bushes.
I hope someone can give ma good tips.
Regards
Patrick
Old May 28, 2015 | 12:30 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
whole sub frame has to come off the car to replace the bushings.
Old May 28, 2015 | 12:41 PM
blackbenzz's Avatar
haters crazy
If it's the same as the CLK and you are talking about the bushings that go between the frame and the body the whole subframe does not need to come off. You unbolt the front 2 and tilt the subframe down, use a special tool (or air hammer) to extract the old bushings and press new ones in. I never had to do it on my E55 so it may be different
