stay away from 2007 e63?
Often people who open threads lamenting the damage or destruction of their engine are first time posters (not all of course) who seem to want an online record of their "screwing over" by MB, many times they do not follow up and post the resolution of their problem, and I'm curious how much they pay attention to maintence or signs of trouble that might of mitigated their issue somewhat. These are complicated high performance machines which are often driven very hard, things are going to break and wear out; and the driver and environment are factors. The weak links will become apparent over time, design flaws too.
I need all lifters etc, and the both camshafts replaced. I had significant cam lobe wear and markings on the lifters. I opted to have my head bolts replaced as well for peace of mind.
Here are some pictures. It's just a close up of a cam lobe and a lifter but the wear was on all lobes and lifters.
The "clacking" sound is VERY noticeable. The first time I heard it, I thought I bent a rod. It MAY be a little hard to hear if you're sitting inside the car when you turn the motor on. I'm paranoid so after I start my car I always open my windows and just listen for anything out of the ordinary.
I can't wait for him to send me pictures of the head bolts. I'm betting that they're showing signs of wear.
http://www.jacobregarlaw.com/Blog/20...or-the-M1.aspx
Is this being covered by aftermarket warranty? If not, is MB covering some of the costs? In either case, how much to address this and replace the head bolts?
The gist of the lawsuit is basically what folks already know - you're on your own once you are out of warranty. Nothing new there...
After much negotiating theyre charging me $9100(the remainder of my policy payout) to replace the lifters, cam shafts and head bolts. Getting this done at my indy would've costed about half that. Either way, at least I can drive with peace of mind from now on.
On the cam lobe wear, it happens frequently on OHC engines with high lift cams and hydraulic lifters that don't utilize hydraulic roller lifters. Hydraulic roller lifters will cure this issue from happening but I'm not sure anyone makes them for the MB engine.
I'd call and find out what your cap is just so you know how much you have to work with.
. Just take care of the ride and enjoy the heck out of it!
