Buying a '05 E55..
Here is a list of what has been done to it under his ownership.
2005 E55 AMG 103,930
Maintence Paid Date Installed Milage
Falken Ziex ZE912 tires 265-35-18 (2) 120 Jan-14 103,987
Mount & balance 30 Jan-14 103,987
World Motorsports black lug bolts 14x1.5 27mm ball seat 120 Apr-14 105,015
Bosch 0 392 022 010 IC Pump 119 Apr-14 105,015
Bosch voltage regulator 91 Apr-14 105,015
Remote key case shell 9
OEM Mercedes fuel cap 40.5 May-14 105,789
Bosch Icon OE Style Beam Wiper Blade, 26" 36 Sep-14
Oil Drain Plug Gasket; 14x20x1.5mm; Copper (x4) 1
Oil Drain Plug; 14mm Diameter, 24mm Length (x4) 12
Mann-Filter HU 718/5 X Metal-Free Oil Filter (x2) 22
Mann-Filter CUK 3172 Cabin Filter With Activated Charcoal 23 Sep-14 106,958
Oil & filter change 70 Sep-14 106,958
Mercedes dealer drain plug + gaskets Sep-14 106,958
Valve cover gaskets (left + right), Victor Reinz 24 Sep-14 107,145
NGK spark plugs #LFR7AIX (one step colder) (16) 124 Sep-14 107,145
azn optics 5000k wedge bulbs 19 Oct-14
Philips 9006 CrystalVision Ultra high beam 16 Dec-14
Philips H7 stanard replacenebt bulb low beam 26 Dec-14
ACDelco ATX14BS Speciality Powersports auxiliary battery 74 Jan-15
AutoCraft Platinum main battery 189 Jan-15
Falken Ziex 912 245/44/18 97w xl 360 AA A (2) 220 Feb-15 109,104
Tires mount & balance 62 Feb-15 109,104
Exxon Mobile Jet Oil II - 1 qt supercharger oil 26
SBC replaced under warranty 0 Feb-15 109,240
Brake fluid replaced 0 Feb-15 109,240
Mercedes serpentine belt 40 Mar-15 109,370
Mercedes supercharger belt 27 Mar-15 109,370
Key fob batteries 20 Feb-15
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
