OBD 2 adapter Codes.
Old Jun 24, 2015 | 12:10 AM
T9ja's Avatar
2005 E55 amg
Can someone tell me what these codes are: P0413, P0448, P0458, P0135, P0155, P0141, P0161, P0136. They have to do with the powertrain. Pulled these codes with the obd 2 adapter.
Old Jun 24, 2015 | 07:37 AM
mkiv_tdi's Avatar
Jetta TDI [Daily] , Audi A8L [Sold], '12 STI [Sold], '06 E55 [Sold], '05 S500, '15 GLA250
Did you try and google it? (Not trying to be a d!ck...)
Old Jun 24, 2015 | 07:53 AM
T9ja's Avatar
2005 E55 amg
No. I was wondering if anyone has ever pulled those codes, and what they did.
Old Jun 24, 2015 | 08:45 AM
uraberg's Avatar
2006 E55 AMG
You posted these same codes a month ago, and you still have not even looked them up yourself?
I just quickly googled all of these, just out of curiosity.
Yup.
Old Jun 24, 2015 | 08:49 AM
mkiv_tdi's Avatar
Here's a bit of legwork I managed to do to get you on the right path
http://bfy.tw/Ugj
Old Jun 24, 2015 | 09:21 AM
T9ja's Avatar
2005 E55 amg
I looked them up already. Now, what I really need is a fix/parts to the problem, if anyone has pulled the same codes, and see what they have done to clear the codes.
Old Jun 24, 2015 | 09:30 AM
mkiv_tdi's Avatar
Again, don't take this the wrong way, but it might get your further to copy/paste the description of all of these codes instead of the alphanumeric code.
Most people probably don't know what "P0155" means off the top of their heads. And they're probably not going to go out of their way to look up each of your 8 codes for you to try and understand your problem.
But if you posted in this style for each code, people might be more willing to help:
P0155 may mean that one or more of the following has happened: O2 Heater element resistance is high Internal short or open in the heater element. O2 heater circuit wiring high resistance open or short to ground in the wiring harness
Just sayin'. If you want people to help, it's probably best to help them and give them as much info as possible...
Obviously you've got an issue with your 02 sensors... have you noticed a change in the car's performance and/or fuel economy?
Old Jun 24, 2015 | 10:25 AM
T9ja's Avatar
2005 E55 amg
Thanks for your help. No, I have not noticed any performance change. I am trying to delete secondary O2 and get a code to erase it though.
