Feeler..... Twin Turbo E55 for sale
#102
[QUOTE=RedBullJnky;6494518]It was great talking to you brotha. I appreciate all the info you shared with me. Very useful... Now it's time to step up the game! Will keep in touch.
#103
you to Hate
[QUOTE=c55asleep?;6497265]
I'll see you soon.
#107
you to Hate
I'm doing a roll racing event on Saturday so nothing tomorrow. Plus my daughter flies in from NC today and I'll be doing some things with her.
But I'll let everyone know when I'm going to hit the 1/4 mile. It's hot as shi$ down here right now, so I guess it's time to turn the meth on.
#109
you to Hate
Here's one from last time from last time. Watch the bottom left corner and you'll see him at my rear bumper
#113
#114
you to Hate
Correct, but it can be done.
#115
#116
you to Hate
I don't know much about Speedriven, but mine seems to be fine. I hit 24psi the other day, but was to lean for me. So I turned it back down. I don't think my stock trans is gonna hold that much.
#118
Maybe the better question is can the v12tt engine/ecu be modified to run on 8 cylinders? If that could be done, then getting ecu working with v8 block and turbos may not be that difficult. Of course that assumes v8 and v12 have same sensors and engine control systems.
#119
you to Hate
The trans was a reman that I got a few years ago after I blew the original at the track in GA while racing with chawkins. It has the UPD 3000 stall and a custom tune and that's it.
#120
So if you're fluent in German & have the time to read/go thru tons of pages of codes YES it can be altered, though to what degree IE actually shutting off 4 of cylinders etc is a mystery to me.. Go ahead & try as Elliot has noted he must be using a 600/65 ecu w/some good sucess I know they used a 600 ecu/tcu on the EV12 speedriven helped make IE was E55k swapped to 600 v12 but did/does have running problems per the last owner Harry from this forum.. V12Godspeed was the original owner/ had it made so he will have ton more viable info on the subject hopefully he will chime in
#121
you to Hate
#123
