CEL after valve cover gaskets...which hose is loose?
I know there's a vacuum leak some where, but I can't figure out where. I believe Shardul pointed out this hose in circled in red, but it appears to be on from both ends.
Where else should I look?? Someone please help..
This is the drivers side of the engine:
Have you checked for leaks by letting it idle and gently spraying brake cleaner in the area to see if the idle stumbles?
What code are you getting?
So assuming that is true, get a mirror and look at the bottom of the throttle body with a good flash light. Follow all of the breather hoses and try to physically grab them to make sure they are attached and do no have holes worn in them anywhere.
