Timing
Hulk those numbers I sent you in the pm where off on the timing by 8-10 degrees.
Only 2 parameters from obd with dashdaq
Iats
Timing
Rest goes through the zt2
You have to see of there's any retard, with your logging you can't see that at this time.
If the tune is calling for 18* but you see 14 or 15 doesn't mean it didn't hit 18* at one point that's where the logging will show you if there's dips in timing and you know if there's knock
Now whether or not the tuner will tell you what timing they are commanding....
I've had a hard enough time prying commanded AFR out of a certain someone let alone timing...if only we could tune these cars ourselves.
