New e55 downsides of meth
get a bigger H/E for use - ever since I've replaced mine I haven't had heat soak at all (in my style of driving) but if you're looking to put down crazy power and sustained high speed runs - then meth is a good choice... search on here (or other sites too) lots of work done with water/meth injection...
(Headers, 82mm TB, drop in filters, 550 injectors and tune)
Up the boost and you will benefit from WI for cooling.
More boost=more heat=less timing=less power
My primary concern was if the water runs out, that engine goes kaboom. It appears since I am primarily adding it for cooling and not for power, there would be no issues since the engine would just get hot and timing would get pulled. Correct me if im wrong.
You're not tuning for it. No kaboom
Obviously if you tune the car improperly with Meth it adds an enormous amount of risk or if you run too much meth it adds an enormous amount of risk but both of those factors come down to a proper tuner. They should be able to advise correctly.
Many of the risk factors of meth can be mitigated by choosing the appropriate tuner.
Exactly what I was thinking!
