plug in the e55 in winter ? ????????????????????
Old Oct 28, 2015 | 06:40 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
hey
my e always dies in the winter... I recently change both batts and I know it will still die in the cold in my garage.
what do you guys use to plug it in ??? teach me
Old Oct 28, 2015 | 07:25 PM
Shifter's Avatar
E55, SL63, ML550
When my car is in storage I use the factory MB maintainer. I think it's around 150.
Old Oct 28, 2015 | 08:17 PM
SICAMG's Avatar
2005 e55 AMG
I put a cigarette lighter socket at the rear bumper and wired it to the battery. Real easy to get to and plug in the charger when the car is sitting. Now I do not have to open the trunk to do it any more.
Old Oct 29, 2015 | 04:17 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
I just unplug the battery.
Old Oct 29, 2015 | 06:11 PM
MTV10's Avatar
E55 AMG & C63 AMG
Trickle charger.
Connect it to the battery and you're good to roll.
It just maintains the charge.
Old Oct 29, 2015 | 06:26 PM
ekalb's Avatar
05' E55 Wagon, 18' S90 T6, 00' M5, 19' F150
I have always plugged my cars in through the cigarette lighter with a trickle charger and have never had any issues. Today I went to plug the same trickle charger into the 12v outlet in the front ashtray area and the charger just blinked saying it wasn't connected. Is there a better 12v source for this car or does it need to be direct wired to the battery?
If it's direct wired to the battery in the rear, is it also charging the 14BS AUX battery under the hood?
Old Oct 29, 2015 | 07:24 PM
Hotsauce55's Avatar
2005 E55
Is the w211 really that bad? My batteries are good to go but should I expect problems when it goes below 0?
Old Oct 30, 2015 | 08:11 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
https://mbworld.org/forums/w211-amg/...ml#post5563766
Old Oct 30, 2015 | 08:14 AM
realien's Avatar
2016 AMG GTS
I use these on my motorcycle, they work great, should work for the car too.
Amazon.com: Deltran Battery Tender (021-0128) 1.25 Amp Battery Charger: Automotive Amazon.com: Deltran Battery Tender (021-0128) 1.25 Amp Battery Charger: Automotive
Old Oct 30, 2015 | 09:15 AM
novae500's Avatar
W211
ctek charger for the rear battery. then would also rotate to do the front if you park it during the winter. I drive it at least once a week weather permitting not being salty, snow/ice.
