Twin TB. Map questions
Has anyone had their 55K mapped for two TB? I'm looking for someone experienced to do my car. Tried both EC & Weistec but neither can help. I'm overseas too which doesn't help.
Can go piggyback with Motec as a last resort but the cost is astronomical. This is for the Weistec blower. Heads polished & ported, bigger valves next (following Sir-Boost-A-Lot's DIY on beehive springs upgrade).
A twin TB setup would be nice or a single huge TB like most domestic cars. Unfortunately you are going to be fighting an uphill battle to get either working. It would definitely help feed your blower, especially at higher sc rpm speeds. The 90mm is better than 82mm but I still don't believe it is maximizing the potential
I wanted to try this right after I ran the 90mm set up but I at the time my fabricator took a new job so I forgo the project.
But try split just wire #1 & #4 (not sure but they're the ones that open/close the tb). Just run those two wire to the second tb. By doing that you're fooling the ecu to thing that it's still run one large tb. If that doesn't work I will run a micro switch, like the one for nitrous set up, so the second tb only open when wot. That's my little contribution on the subject. Good luck.
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Sir boost a lot was fitting one of these. http://www.kennebell.net/KBWebsite/A...ts/mam1880.htm
Not sure if it's working though.
Edit. Unless I go with motec in which case both TBs can be hooked up and programmed independently.
Woody (who is the developer of some of Needswings' products) seems to have sorted this out on his SRT6 crossfire (amg 112k motor). Perhaps it is what you are looking for?
http://www.crossfireforum.org/forum/...g-my-srt6.html
Cheers,
Chris
Cheers,
Chris
Cheers,
Chris
Cheers,
Chris
Just to update this thread. I'm at the finishing stages of twin TB air inlet design. It will be machined next month, in time for when my engine and heads are back from Weistec. I'm going with Motec ECU which will control both throttle bodies independently. It will be a few good weeks before the next update so stay tuned.
