About to change alternator, any tips or DIY? Searched already.
http://www.ebay.com/itm/24-Flexible-...114964&vxp=mtr
When I replaced my heater control valve, one of the clamps was rotated in a matter that I couldn't get straight at it with regular pliers or vice grips. I spent an hour removing one clamp that would have taken 30 seconds with this tool. I do own one now.
I just dropped off my batteries. Looks like both batteries were just barely under normal condition. Guess thats enough to make the electronics unhappy.
Also look into resetting your windows and sunroof after disconnecting the battery. Basically on the windows you go down and hold for 5 seconds after fully open and do the same on close. With the sunroof you do tilt up and hold for 5 seconds, close and hold for 5, slide open and hold for 5, close hold for 5. Non of the one touch open and close was working every time I disconnected the battery. I thought I had a major issue with the sunroof when I tried to open it and it sounded like it was going to break and would not go back more than half way.
.[/QUOTE]
what was your voltage reading when car on with reman? Mine is at 13.9-14 volts. And steadily going up as a drive the car more. Little low but battery is old.
My battery is very old and it tested fair. They recccomended to change the battery. Consdering switching batteries with a new to see if red battery light turns off. Will head to dealer on Tuesday to have it checked out before. Then we will see where we're at.
Thanks for the reply.
Ive had the front battery for 2.5-3 years How long doe they typically last?
Gotta check to see if my front motorcycle battery can be opened up to add battery acid. Where do you buy the acid?
Mine is original, so.. 10 years. If it's dying at 3, acid probably won't help.
NAPA sells it.
NAPA sells it.
50 dollars is not an issue. I was asking a simple question about how long they normally last. My original lasted a really long time maybe 6-7 years. But, this last one (motorcycle battery not OEM) only lasted 2.5-3 years. Maybe, it was because my alternator was giving out and it killed the battery sooner or a front battery relay. I don't know, Hence the question.
I went to the dealer and they are charging me to check the issue. Hopefully, they can just turn off the red battery light. I already changed new AGM rear battery, new alternator and aux battery showing good health. This is annoying.
1. replace vr
2. replace front and rear batteries
3. replace bcm
no more red message. You might need to wait 5 min or so and the red message goes away. happened to me after replacing the bcm. i have an extra bcm if you are in need of one.
Great thanks, I will pm you
I will take a look when I put the car on the lift to continue with some scheduled repairs and report back.
first thing I did when I got my reman alternator was swap that cheap generic vintage regulator with a new boa he Vr. that is one the main components. The generic could fail easier. Try it, it's quick install I bought mine here from a member new in box.
Let me us know what you find here if you could. Could help someone who se down the line.
The second time around was much faster as I didn't waste time trying to work around coolant hoses and pulleys. Best way is to remove the double pulley and clamp off and move as many hoses as possible. Pretty easy after that.
