S/C pulley vs. Crank pulley
Looking for input from the veterans or anyone that has experience with both.
Does the 83mm make as much power ad a 168mm?
Is the clutched 77mm making as much as a 180mm?
Cost aside, just actual gains.
Search the forum for failed supercharger pulleys before making your decision. In terms of power, the supercharger is mechanically driven and the speed can be calculated using a formula.
It really depends on what kind of power u want and cost of install. To answer your questions the 83mm produces alittle less than the 168 crank. But it also generates a lot less heat than others. The 77cluched and 180 are pretty much the same. They both generate a lot of heat. With stock cooling you will heatsoak.
Do a google search on both. There is enough info out there to keep you reading for weeks.
Oh okay so they are pretty even. I have a 83mm now and debating whether to use a 168 my cousin never used or to just use a 77mm
