2003 E55 radiator replacement.
Old Nov 9, 2015 | 10:45 PM
MZE55's Avatar
2004 E55 and Audi TT 3.2
I'm replacing my old Valeo radiator with a new Nissen, any one have an idea how much transmission fluid the radiators hold?
Old Nov 10, 2015 | 12:58 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
Your trans cooler lines are connected to your radiator correct?
If so, which i'm sure they are your concern is irrelevant pertaining to how much trans fluid the radiators hold, all you would need to due is check actual trans fluid level from dipstick tube.... Once that level is correct your lines are filled to spec....
Old Nov 10, 2015 | 01:29 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
less than 1/2 quart
Old Nov 10, 2015 | 09:42 PM
MZE55's Avatar
Thanks Shardul. I am putting together everything needed for a radiator, H/E and pump install. I picked up the transmission dipstick and all that was left was how many quarts of transmission oil to buy. Thanks for the info.
