some questions about modding the beast.
I finally installed my headlights, plm heat exchanger, belt wrap kit, and ic pump. I did not split the system.
Do I still need to bleed the heat exchanger or should it bleed naturally through the system?
Also I have a 77mm clutched pulley waiting to be installed. Do I need a tune to install or install it then take it to get tuned? Also does anyone know what the gap is supposed to be and the torque spec on the pulley?
I just had the fuel pump and filter replaced so from what I'm reading I don't need 550cc injectors?
Thanks for all the help guys. I'm finally starting to get somewhere.
