Is there a way with DAS to....
Keep the cars suspension from dropping when it reaches over 70 mph? This camber tire wear is really getting old. I always drive in comfort mode, but regularly drive over 70 on the highway back and forth to work. If it can be done, please advise where in DAS I need to go. Thanks!
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
another solution is to raise the car a bit higher to when it lowers after 70mph it will not be too low
Another way to skin this cat is with the programa lowering module... (at least for the R230) it allows speed dependent height adjustment.
However, it will only raise the car to the extent that you have lowered it (with the module) SO ... you would have to trick it with lowering links (or star level adjustments) if you wanted to have a stock ride height .
Cheers,
Chris
Cheers,
Chris
Get adjustable camber bushings, or links. This will allow you to set the camber where you want it to be. I have mine set to .8 degree negative in sport 2.
