Retro fitting E55 parkmatic on to a E63 front cover
Old Nov 16, 2015 | 03:29 PM
gts007's Avatar
06 E55 AMG, 86 Corolla,87 E30,02 LSB M3
I been reading a few tread over the year's and no one really post picture's on how to retro the parkmatic on to a e63 cover utilizing the stock parts off a e55 bumper assy. Here's a few picture i found on my old phone when i did it few year's ago.
Parts require: e55 parkmatic wirning,sensor's and factory bracket's (correction on the Pn 171-885-00-14)
E63 Front cover with the factory bracket sensor in place.
remove them using a flat panel puller or a putty knife.
Make sure to remove them and clean the surface well before using adhesive or epoxy to glue new bracket in place. (recommend to use a 600 grid sand paper just to rough it up for the epoxy)
The four sensor's that goes on the corner will need to trim half of the bracket and shape the sensor's to clear the lip of the edge (look at picture 4)
i use a bit of glue to set the position then apply the epoxy
same for the side's
Make sure you test the sensor's first before building back the bumper.
Hope this info help's.
Old Nov 16, 2015 | 07:24 PM
JoeNobody's Avatar
Mercedes
Excellent write up.
Optionally you can drill the holes out to the larger size so the rubber washers then fit. Obviously you'll need to do this before having the bumper painted.
Old Nov 17, 2015 | 08:02 PM
gts007's Avatar
Joe, i did use the sensor spacer but didn't want to enlarge the hole it would of look uneven compare to the center so i just end up sanding off the sensor's a little. But that can be a alternative way.
Old Nov 27, 2015 | 02:44 PM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
nice write up, i did mine this way with the new brackets
Old Nov 27, 2015 | 05:18 PM
£ C43 £ AMG £'s Avatar
E55K AMG
Hi mate
are these the same thing?
http://www.ebay.co.uk/itm/2317365119...%3AMEBIDX%3AIT
Old Feb 17, 2016 | 12:54 PM
gts007's Avatar
nope c43
