2006 E55 - strange door lock problem
Old Nov 24, 2015 | 06:02 PM
erupert66's Avatar
'05 SL55
I am having an issue with the passenger side front/rear locks ONLY when pulling away from stop. If I lock with the remote, all 4 lock. If I drive away, the driver's side locks and the passenger side locks/unlocks twice and remains unlocked.
Any ideas?
Old Nov 25, 2015 | 10:52 PM
ES EF ED's Avatar
CTS-V ///
Check the door pin switch on the passenger side.
Old Nov 26, 2015 | 07:55 AM
Shadow5501's Avatar
Car free at the moment
Common problem. It's the door lock actuator. Not sure if the actuator can be repaired, I had warranty so just had the dealer replace it. I have heard the problem described as Mercedes machine gun door locks. Try googling to see if anyone has posted a repair procedure.
Old Nov 27, 2015 | 01:37 PM
erupert66's Avatar
'05 SL55
Found another thread here. Simple as spraying the boot that the lock shaft passes through with some silicone to keep if from dragging and it's working perfectly again.
