Oil leaking from oil filter housing?
2006 E55 AMG
So while in the process of replacing my alternator I notice a little fresh oil around the bottom of the oil filter housing. Apparently it leaked on the belts and splattered oil around a bit. Is there a seal around this area that is notorious for leaking, or do I just take apart the housing and replace everything?
just making sure, you mean the oil filter housing on the engine? Thats from aluminium. It connects to the block by a big bolt, and there is a rubber seal ring between the block and the housing. Its a cheap part from dealer, and easy to change. cant really see why would you replace the housing itself?!
