fabtech tank act temps any log at track?
99 ford lightning
curious if anybody else logged act temps with the fabtech tank. going through these data logs Im still shocked that sunday tat the track temps were in the low 40's vs upper 50's when I ran the cobra tank and stock heat exchanger the cobra tank set up was almost 50deg cooler at the track. Not sure if some ice melts and blocks the ic lines but that doesn't make sence. guess the only thing to do is swap tanks and just keep the heat exchanger.
