Broken supercharger pulley ?
2004 Mercedes Benz E55 AMG
Well I think my supercharger pulley is going out , the seal to the bearings came out after I started it this morning and as its warming up & I hear a small consistent ping noise so I pop the hood & see that the bearings are exposed & I shut it off to access the situation , any ideas of what it will run here in Cali for parts and labor if it's just the pulley
^ Look he's been a member for a week (or two) and already has 24 posts, with a lot of them starting new threads asking questions????
MBWorld has a nice "search" feature that works quite well - I still use it.
I know that. I participated in most of them. Use the search feature.
It's a good job for you to try. Make sure after you get the bolt out keep in mind the washer won't come off untill you pull on the pulley. Make sure you don't let it go into your fan shroud.
I would replace that bearing before going anywhere further bud. If you want there is a ton of performance super charger pulleys, sizes and clutched/fixed.. So there are many options for you.
I'm gunna go with the red seal nachi bearing that runs about $90 ,here is the part number to nachi bearing 45bg07s5aig-2dl
Also remember when tightening the supercharger back on to correctly torque it, don't over tighten as you can snap the bolt. There is an idler tension pulley which you will start at first to release tension of course so you can slip the belt off, in case you didn't know about it. Good luck
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
i did it myself and was pretty easy if you know what you are doing.... easier if you have a bearing press, which i didnt so i made my own makeshift one
https://mbworld.org/forums/w211-amg/...g-install.html
