Need help: fuel pump issue
Fuel pump does not make noise or pump when key is on/crank
I have
replaced new CPS (of course won't fix)
checked the relay (A) and fuse 4 (20). They are all good
already remove the seats and caps to access both left and right side unit
Can both be bad at the same time?
Can someone please tell me how to check for both unit? (which wire should have 12V+ when key is on or crank?)
There are 1 plug on the right (4 wires, brown-red/blue-brown-red/blue) and 2 plugs on the left (1 small-3 wires gray/brown-green/brown-red/yellow and 1 bigger plug-3 wires green/brow-blue/white-blue/black )
Much appreciate!
I checked relays on the rear SAM driver side. There is anotherone fuse box under the trunk carpet right next to the battery. Did not know there is one on the passenger side?
Thanks Rocman8!
