Can anyone explain the feeling of supercharger belt slip from the Drivers seat?
Old Jan 26, 2016 | 09:01 AM
FLE55AMG's Avatar
2006 AMG E55
Trying to figure out if that's my problem
That being said I have other problems, but those a better suited for a mental health professional
Old Jan 26, 2016 | 10:35 AM
Denroll's Avatar
'06 E55
If it starts to feel a little slower than it used to, or if you are on it pretty good and you let off the throttle abruptly and you hear a belt squealing.
From under the hood, pop off that front engine cover and see if there is any rubber dust built up on the bottom side of it. Give it a good cleaning and put it back on so you can tell if any new stuff builds up.
The good news is that changing the front belt is extremely easy. I also suggest looking into getting the belt wrap kit. It adds an extra pulley to the system that puts a lot more of the belt in contact with the crank and supercharger pulleys.
Old Jan 26, 2016 | 11:08 AM
FLE55AMG's Avatar
2006 AMG E55
will it give you intermediate power on then off at WOT?
Old Jan 26, 2016 | 01:43 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Aside from the car falling flat on its face,like your driving an E500 ,data logging boost would be the way to go ,as far as belt squealing after punching it out and letting off after a burn out ,that's happened to me with stock set up and two different types of belt wrap kits ,I think that's just the s/c not slowing down as fast as engine ? Whatever causes it ,two belt wrap kits didn't stop it ,for me anyway
Old Jan 26, 2016 | 03:35 PM
Velociabstract's Avatar
SRT-6
If it's slipping you should see some rubber dust around the supercharger pulley. It's more like the boost and power stop building early but it won't go from full grip to no grip at all. Falling on it's face could be from the intercooler pump or tensioner being weak.
Les
Old Jan 26, 2016 | 05:33 PM
FLE55AMG's Avatar
2006 AMG E55
Les
Check the IC pump even bleed it last night that seams fine.
Eric
Old Jan 26, 2016 | 05:44 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Also look at it will it's at idle. I test drove one where the belt tensioner pulley had a crack in the bracket. At WOT it felt like it was cutting in and out. But if it's slipping like you say there should be belt dust visible.
Old Jan 26, 2016 | 08:29 PM
RikTT's Avatar
A bunch of TT's
Personally with the S/C belt off, I feel it's very very sluggish in comparison to any normal V8. If you have a BWK, it adds time to the swap belt.. I've popped a S/C belt with BWK & it also got tangled with serp belt/CP knocking off a serp belt rib. So much for that no lift WOT pull.. Been good since.
Maybe time for a new S/C tensioner itself especially if high mileage & never replaced.
Old Jan 27, 2016 | 01:13 AM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
If you are not already equipped to, you need to "gear up" for (at the very least) data collection that goes beyond what you see on your instrument cluster.
In other words, (and for this issue) you need to look at your boost, your IAT and check if you have any codes (pending or otherwise).
You can buy a simple obd2 bluetooth plugin for $11
Amazon.com: Foseal Car OBD2 OBD 2 OBDII Bluetooth Diagnostic Scan Tool Check Engine Light for Android & Windows System Torque Pro: Automotive Amazon.com: Foseal Car OBD2 OBD 2 OBDII Bluetooth Diagnostic Scan Tool Check Engine Light for Android & Windows System Torque Pro: Automotive
and then download the free version of "torque" and gather some data. You will be glad you did.
Reading boost is always interesting and will tell you if your SC is being disabled (and/or suffering from unusually bad belt slip)
IAT (intake air temp) is interesting to monitor as well, and in this case will tell you if your charge cooling system is keeping the intake cool enough to keep the ECU from disabling the SC
Reading the codes is ALSO otherwise useful, but in this case may tell you about bypass throttle failures that cause the ECU to disable the SC (sometimes intermittently) or you may even have a primary throttle issue.
Of course there are other things that may cause the symptoms you are guessing you are having ... but it is time "gauge up" and see what you got. There are many here who are happy to give you suggestions as to what your butt dyno may be feeling ... but if you want to understand what your car is doing when it feels right and compare it to when it feels wrong ... you need to collect some data
EDIT ...
I just noticed in another thread (alternator) that you are already data logging ... (sorry if I came off "preachy" above)
why don't you post some of your data in this thread? Is your boost reading lower than you expect? Does it have fluctuations that coincide with the perceived drop in performance? You mentioned you checked you IC pump and re-bled - were your IATs high? (perhaps that is pulling timing?)
Cheers,
Chris
Old Jan 27, 2016 | 12:18 PM
Boosted-AMG's Avatar
2005 E55, GMC Whipple Supercharged Quadrasteer Denali Pickup,Big Bored Hyabusa with nitrous
I agree with latemodel21 about the OBD2 reader. They are so cheap now and can be very useful. If your going heavily modded I'd recommend a zeltronix wideband and data logging set up. You should be able to rule out belt slippage easily. As others have stated, the kind of power loss your describing would leave obvious belt dust/residue .
Old Jan 28, 2016 | 03:50 PM
FLE55AMG's Avatar
2006 AMG E55
Amazon.com: Foseal Car OBD2 OBD 2 OBDII Bluetooth Diagnostic Scan Tool Check Engine Light for Android & Windows System Torque Pro: Automotive and then download the free version of "torque" and gather some data. You will be glad you did.
EDIT ...
Cheers,
Chris
Chris i only asked if someone can explain what belt-slip feels like from the drivers seat, Sorry did you answer that question and I missed it or just trying to call me out.
No pitch fork is not needed here just a enthusiast trying to fix his whip.
Old Jan 28, 2016 | 03:54 PM
FLE55AMG's Avatar
2006 AMG E55
It is belt slip, I changed the belt last night and it's all good.
The reason I did not by it was belt slip is because everything was fine until i change my alternator and the car started to have these problems. I know it was not timing because ecu pulling time is usually smooths things out and power is lost. I know these cars have fuel pump issues so I check pressure and that was fine. I know it was not a ignition issue because I never had misfires or CELs. I also did not think it was the belt because it was very clean around the pulleys and the belt looked good no cracks or anything. Thank you everyone again for the help.
Old Jan 28, 2016 | 04:58 PM
I was trying to help you out, not call you out. I'm here to for the former and not the latter. I'm sorry I was unable to make that clear. When you mentioned checking the charge cooling in your car, I assumed you wanted other types of input beyond what you had already gotten... I'll try to avoid making that mistake again.
Good to hear you got it all sorted out.
Old Jan 28, 2016 | 05:24 PM
FLE55AMG's Avatar
2006 AMG E55
It's all good man! I'm reluctant to post my date findings because I can only view it real time with my system and I think it's delayed form the WiFi Module to my phone. In my data I could not really tell if I was loosing boost because of that delay, it was not like going from 12 to 10 back to 12 as a example.
But in my data after bleeding my IC system I did recovery back quicker so Top Tip when coolant is changed defiantly bleed your IC system just for good measure.
I made a huge mistake buy not trying to eliminate the simple causes and start looking at the more complex issues it could have been. Everything I read about belt slip from this board and Mustang and Corvette boards no one complained about unsmooth power delivery.
I only had turbo cars so I have a learn curve he with the SuperCharger.
