Strange whining sound even after car killed
Old Feb 3, 2016 | 11:38 PM
SCarterMusic's Avatar
2005 E55 AMG
New to mercedes, Just got a 2004 e55 - Last week, on a cold day I heard a crazy whining sound. It continued when I killed the car. Here is a video of the sound.
Shortly after, I have a check engine light.
What is this noise? Could the check engine be related?
Thanks for helping a new guy out.
https://www.dropbox.com/sc/nyspt93xy...swDAkYhRVIaWwa
https://www.dropbox.com/sc/9vmzh5y05...MtUbOh0y6afFaa
File Type: mov
File Type: mov
Old Feb 3, 2016 | 11:45 PM
Rocman8's Avatar
E55
your secondary air pump relay stuck on and killed the pump. replace the relay, fuse, pump, and clear the fault codes.
Old Feb 3, 2016 | 11:56 PM
2005 E55 AMG
Wow, ok, so I just had the secondary pump replaced. Do you think the pump is likely out now? So replace again, along with relay and fuse?
Is it possible it was just the relay?
Old Feb 3, 2016 | 11:59 PM
Rocman8's Avatar
E55
yeah because everyone just replaces the pump when it dies and not the relay when in fact the relay is the real problem here because it sticks on and runs the pump constantly till it shorts the pump and pops the fuse.
try a fuse and relay and cross your fingers but im guessing its out again.
Old Feb 4, 2016 | 08:06 PM
hayseed's Avatar
04 e55
disable pump via star - not needed - save future headache
Old Feb 4, 2016 | 08:08 PM
Rocman8's Avatar
E55
Depends where you live if you need to pass smog
Old Feb 4, 2016 | 08:21 PM
2005 E55 AMG
Well, I am ordering a star kit anyway. And I had the CEL when i bought it, found a place that helped me to pass emissions, Im sure I could go there again. After pump was replaced CEL went off, after this issue, its on again.
I may just disable it. Is changing that pump fairly easy? If I get the car up on ramps Im guessing I could figure it out.
Thanks Guys!
