Who's running a 77mm clutched SC pulley and a larger CP?
Old 11-30-2017, 02:24 PM
The Fly 1's Avatar
E-55,IS-250
Originally Posted by MACEDON
180mm crank and stock SC
Heat is pretty bad, I could barely do one pull to about 70mph before the supercharger kicks out at 180F
A PLM cooler has helped that, easy install. You already have the equivalent (77mm), I would just leave the car alone unless you're interested in spending a lot of time dicking around with cooling. Past splitting/upgraded heat exchanger your options become: meth injection, big trunk tank, and killer chiller.
are you running stock headers and throttle body?
Old 03-08-2021, 03:39 PM
Ed P's Avatar
2004 S55 AMG
Any updates?
Hi!
I’m looking to install a 77mm SC pulley and was wondering what the outcome was from the above posts?
Are 550cc injectors enough and are they even needed?
Quick Reply: Who's running a 77mm clutched SC pulley and a larger CP?
