It's Official! E63 Engine Grenade...
Well since the OP already has an E63, let's quit telling him to avoid the M156. I doubt OP is just going to take a bath on the car, send it to the scrapyard and spend the money on a different car just because some people have issues. You can find horror stories about many high end, high performance cars. They are in nature, high strung and easy to break for the most part. I would do more research and go for the first engine you found if it will work with minimal changes. You already have all the accessories you need from your current motor so none of the things the shop mentioned should be an issue. Very easy to swap stuff over when you have two motors sitting on the garage floor in front of you.
I think the best pro-active way to handle this issue for anyone who views this in the future while considering a car with the M156 is to get an aftermarket warranty.
i'd buy that rebuilt engine...new head studs...having that swapped in maybe cost you 1,500 in labor for the in and out procedure from a solid shop. not sure what dealer quotes for this job though.
