Supercharger Temp
Supercharger Temp
After normal driving how hot is your supercharger?
1) Hot = Don't Touch
2) Very Warm = You can touch it quickly but best not to keep fingers in too long.
3) Between 1 and 2
After fairly normal driving mine was pretty much Hot. The water in my engine bay tank was boarder-line cold last night (63 degrees outside).
YES! I am ordering data logging gear!
TK
PS -Car has been dropped at mechanics place for the 84mm s/c pulley, 82TB, 550 injectors, BWK, 1-step colder plugs, and VRP intake.
3) Between 1 and 2
TK
PLATINUM SPONSOR
Yes, the SC gets to hot to touch quick.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
I was on the dyno Friday. Air/fuel ratio tanked under 10 (not sure how low it went) at about 3,800 rpm.
