HELP ME identify this part!
I was just about to replace the coolant overflow hose that flows from the coolant reservoir to the engine area ( Water pump ? ) when this part snapped off!
The side with the metal clamp is supposed to connect to the hose while the other side snapped off with a plastic part still inside the engine area. Its located slightly under the steering fluid reservoir.
Anyone have a part number or
fix for this ? It would be greatly appreciated!!!
