Wiper Relay Location
Old Jun 4, 2016 | 02:24 AM
SuperChargerE55's Avatar
E55 AMG V8 Kompressor 2004 E 55 AMG Type: 5,439 cc (5.439 L; 331.9 cu in) Supercharged V8 Powe
Anyone please I been searching like a mad man for the Wiper Motor Relay
Front Fuse Relay 56 40A
got the fuse chart but damn to find anything in the fuse box the relays without taking them out is that ok can I do that without messing anything up?
Problem: Broke my Rain Sensor Wire in the OCP
Bought new one but intermitted wiping runs every 5 second instead of when windshield is wet,,
(Command also stays in night-mode)
My local AMG said is the Rain/Light sensor need reset and re-learned...
(Saw a post about pulling the wiper relay close all doors start car, wiper to pos 3 back to pos 0 then to postion 1 and have someone splash the window, I doubt it will work since this is interrupted when car is standing still..)
Any toughs should I forget this and drive to my AMG center?
Second problem when wiper is in postion 1 2 or 3 and I press the washer button the wipers stops working until car is shut of and started again
Everything works before this all because stupid LED bulb install in OCP
Old Jun 5, 2016 | 01:16 PM
Ruthle55's Avatar
e55 amg
Turn car off, turn it back on. Reset it using the stalk. It will work. I just did this, and I didn't need to mess with any fuses.
Old Jun 5, 2016 | 02:13 PM
Stalk?
Oh yea?
Using the stalk what's the stalk? Sorry my English sucks..
Maybe I should check the wires in the Ocp is properly connected. Getting a extra pair of hands this time
So stupid when replacing to Leds I was so stupid disconnect all the wires door instead of just out with bulbs took the whole thing down first. Don't waste of time and change of braking something well
Skinny *** flat cables lol
Old Jun 6, 2016 | 04:59 AM
possible to tell me more??
Ruthle55 could you tell me a bit more what was your problem when u did this, did u also change the wire or?
Mine broke and I been using the car while waiting for the new wire, and if I understand correct the Canbus will of if it detects a problem so replacing the wire the connection somehow is still turned of..
My command also stays in night mode despite set to auto-mode
and got to add all settings has been set to auto.. still
Does your Command display auto-mode work?
Does your auto light work?
Old Jun 6, 2016 | 10:42 PM
Dublinoh's Avatar
E63 AMG 2007
I think by stalk he means the windshield wiper control. Sounds like you would follow the directions you found, but just shut off car then turn key on but not start car, I'm just trying to translate for you, I don't have first hand knowledge for procedure.
Old Jun 7, 2016 | 12:30 AM
Yes thanks brother, appreciate it..
Fixed problem took out the OCP to check again last time I did it alone and was kind of mess with just 2 hands one need 4
So it seems like I have no idea how I managed this but the rain sensor plug that goes in to the OCP was in the wrong plug huuh could just see hmm there isn't really room for it so out and moved back with all the sphagetthi (wirring)
Started car. Move to Dk had my wife spray the window voila
That rain sensor auto mode only works with car in D or Neutral. All windows closed.
(So u don't wet urselfe hehe)
Thanks guys
