best thing to throw out so far
I need to get one of these. This installed in the engine bay? I also want to see how you did the pickup tube.
Does anyone have a great way of making a low profile (flush) cabin filter?
I have no pictures of the pickup I made. It's sloppy but it gets the job done. It's just a plastic tubing that I shoved inside the lower fitting from inside the tank and ran it to the back corner. I also installed some foam used for fuel cells in there since it was sloshing around and leaking out of the cap.
What have you guys done regarding the cabin filter? Everything I've seen is a bit of a hack.
Yeah I just put the screen with the sheet of paper filter over it. I drive it less than 2k a year though so not concerned but if it was a daily then I may have thought of something a little better.
