Intake Dyno Comparisons.
Can you elaborate?
On the back of this, what would be the lock up down to - oil evaporating, bearings seizing up? Definitely interested in the nature of this if you know more.
http://www.lightningrodder.com/forum.../126226?page=1
Post #2. Are you the same person on both forums or did you copy paste someone else’s post? Neither is the issue, I was just after an informed discussion on the subject.
Its to equalize pressure above and below the supercharger. Superchargers have a pressure differential when the throttle blades are closed, since the SC is "sucking" air when the blades are closed and the motor is also "sucking" air. This equalization does help some idles, as most are lean conditions and when they surge and vacuum gets less (motor almost stalls), the AF gets richer and motor runs, vacuum increases as idle surge goes up, motor gets lean. This is a revolving circle. A bypass would help reduce this, but you still have to jet and adjust properly to make it work, its not a cure.
Also, bypass lowers air charge temps at idle because there is less "vacuum" above the sc between sc and carbs/tb's as well as the fact that air is actually being diverted through the bypass to the motor instead of the SC, which means it does get beat or compressed during that stage. This reduces temp at idle, which also helps idle because you have a more consistent temp at idle and therefore the AF doesn't change as much.
So the bypass reduces parasitic losses during vacuum operation and lowers overall temps in vacuum conditions. It does not make more power, only helps during vacuum to boost transition, as the cooler air has less chance to detonate during transient conditions.
Just came across this:
Yes Alex not a copy that other guy who trolls on me is a little fagot and wishes
he can be on my level of Knowledge.If you want pm and I’ll explain more to you about the valve and reson it’s needed and why this happens about premature wear ...to the other guy your so lost on what you say it’s a joke like you .lol. .p .s I must have bought 4 whipples from Dustin and his company I think I would know why to run a valve and not get rid of it .Alex let Mel know if you need help on your setup as I had 2 setups like yours before .Cheers
But anyway I would mount a bypass valve for two reasons. 1. When using a trunk tank: because the supercharger is heating the water all the time in the tank on part throttle/idle without a bypass valve.
2. boost pressure >15 psi+: if the throttle bodies shut fast on boost there will be some sort of heavy shock load to the belt and aggregates including the supercharger without a bypass valve, because the mechanically driven supercharger doesn`t stop - it still runs and moves air.
Adding a bypass valve is a very easy modification. The valve is vacuum activated. So if you don`t like to use it, you can plug the vaccum line. There is nothing to loose.
I have a universal Magnuson bypass valve left including aluminium flanges. Magnuson do not sell them anymore. It was used it on my old supercharged VW bug. If interested PM.
BTW off topic. My supercharged VW bug, throtlle/boost response with a bypass valve.. :-)
Steven
Berlin Germany
https://www.youtube.com/watch?v=eCsFhCWGFpo
Steven
Berlin Germany
Now onto the bypass re-integration. Unless I missed something from your post but since you need to re-route the post TB intake air before it reaches the supercharger, will this not require a complete new air inlet that will have the provision for the bypass valve?
EDIT: Just to word it a little better. With the Magnuson unit, where does the bypass flap reside?
Fyi I was on that forum ..You just joined this forum and your already nut swinging with your girl friend.lol .Trolls 😂
Alex , I suggest you slap the valve back you really need to bleed of pressure in between shifts ..Also, it's a fail safe for when iat sky rocket up wot.If you had a bov then maybe you can get away with it but without you can cause major surging unless you had a standalone...I had a very similar setup on this car minus the dual tb like you ran a valve 100% of the time.Are you on a piggy back?
I’m on standalone and have a Tremec Magnum 6 speed manual behind my engine. Shifts are fine and no surging of any kind. IATs are within 10C idle to WOT. I think what you described is entirely possible on some setups but mine is different. I’m pretty hands on having done all the work myself including fabricating equal length headers for my E55 so if there’s anything to hinder the performance, I’ll be on it.
Steven, thanks for the input. Very interesting to see such an unusual project. Well done!
Here is a pic from my old supercharged bug engine. Magnuson bypass valve. if i would do it again i would connect it before the intercooler. the shorter distance the better.
A bypass valve is nothing else than a throttle body, vacuum activated. When your throttle bodies close, the bypass valve opens and vice versa. super fast. I would connect it between between the selfmade y pipe and the supercharger outlet on your 55. For size comparison, it was a 90mm throttle body on my bug.
I wouldn`t do a bov on a roots or twinscrew. do a research. this is a no no and cheapens the driving feeling imo because you always hear a "woshhhh" even on part throttle.
Steven
Berlin Germany
Steven
Berlin Germany
My boost was measured at 65% throttle. The car hasn't made a full power run yet due to limitation of the fuel system which I'm addressing.
Would be good to know how you determined that your cooling is better and what are the crazy things that require the supercharger to disengage.
Would be good to know how you determined that your cooling is better Your blower is known for its heat and is limited from variable intercoolers set-ups by its overall design. Regardless, it's still an assumption on my part. My bad.
and what are the crazy things that require the supercharger to disengage. Seriously? Uh, like....intercooler failure/supercharger failure/engine overheating to name a few. It also disengages during transmission limp mode to avoid torque damage.
I guess all of Whipple customers are screwed then.
Will find out in September. I have a 1.5 mile event coming.
