Airmatic Buttons stopped working
2005 E55
Hi Guys,
I had WALD LED's installed and used fuse taps for the cigarette lighter fuse so that the LED's turn on once the key is turned. However now my Airmatic buttons stopped working (no lights, no lift). I was told to check the fuses for airmatic. I was wondering if anybody had the buttons just stop working like I had and if there was anything else I should look into. Thanks!
2005 E55
Ok so I found out that the fuse tap in slot 54 in the front SAM was blowing out the Airmatic fuse located in the driver side dash. We completed removed the fuse tap and put everything back to normal and the airmatic started to work once again. About half a day later it blow the airmatic fuse again eventhough we removed the fuse taps for the LED's. Does anyone have any insight on why it's doing this even after reverting back to stock? Also does anyone know of a good location to tap into to get power at ignition so that the LED's run whenever the car is turned on?
Thanks!
Thanks!
