Just changed motor/trans mount. Vibration and gridning sound
Replace motor and tranny mounts on my friends e55. On initial startup the motor shaked quite a lot. Most of the shaking went away but from time to time the motor makes on heavy shak sending a wave trough the car. Thoughts?
There is also i grinding sound from the belt area and around the ac compressor. I moved the compressor and alternator when taking out the mounts. There were also a smell of burned rubber. Thoughts?
Will work on this tomorrow but i wonder if these are common problems.
