Steering wheel
Old Oct 5, 2016 | 09:25 AM
e55joe's Avatar
2014 E63s,2004 E55, 2006 STS-V, 1969 Camaro RS/SS 396, 2012 Centennial GS Corvette
Steering wheel
My steering wheel all if a sudden wont go up or down but it will telescope in and out. Anyone know what the problem is easy fix or no?
Old Oct 5, 2016 | 01:18 PM
oneslow55's Avatar
E55 amg
Check the fuse first and relay if that's not it most likely the motor went bad
Old Oct 5, 2016 | 01:30 PM
e55joe's Avatar
I can hear the motor when trying to move it and it goes in and out
Old Oct 5, 2016 | 02:53 PM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
Had exact same symptoms 2 weeks ago on my 2014 ML. Dealer repair invoice says they replaced a code control unit. Working fine since then.
Old Oct 5, 2016 | 08:20 PM
Devilsfan72's Avatar
09 E63
There is a coupler that breaks that connects the motor to the drive. The coupler can be replaced separately.
Scott
Old Oct 5, 2016 | 09:04 PM
e55joe's Avatar
Scott
Have u done this job? Easy and u have a part number.
Old Oct 6, 2016 | 12:40 AM
cetialpha5's Avatar
You have to search for the old threads, try the W211 forum. Basically what happens is that if you have easy entry/exit on, if you put weight on the steering wheel while it's being moved, it's very easy to snap the coupler. There's a long thread somewhere about how to replace the plastic part. After reading it, I disabled my easy entry/exit feature.
