82mm tb lean hiccup
You being aftermarket and custom work I can imagine you've seen some failures. What kind of failures have you seen?
I just can't see all these tbs being bad. Please enlighten me, I don't think I'm too smart to take advice.
i have the bolt on vrp adapter using the mb sealant to seal both ends. I have removed it and went back to stock and have no issues since.
ideally I should try a new in box one but that would be a special order and well yea, we need to set some limits here lol
Every ecu is different some are more prone to others to get meaning sensitive .It's not the gap of the clutch so it's not that it's more so aiming to fine tune it.
You need to find a tuner who will work with you and has the patience to perfect it.
Next on the list is remove/reseal supercharger and charge pipe gaskets, at the same time replace the MAP sensor with the latest version.
