On the front I had some 18x8 et44 for the winter that JUST fit with so spacers. Those were damaged & I am looking at 18x8 et45 now. I think the 1mm delta might cause the rim to hit the caliper or thrust arm. Anyone have a pair of very small hubcentric spacers?
Did you ever get a pair for up front ? Type/brand ? In need of a small 3mm or so set. I suspect the factory bolt has enough thread to support this size spacer
