Can anyone recommend brake pads and rotors?
Brembo:
https://www.fcpeuro.com/products/bra...mbo-2194210212
EBC Reds:
https://thmotorsports.com/810819-ebc...et-ceramic-pad
Completely satisfied, and I drive pretty hard every now and then. I do recommend adhering to the "break in" method after installing. I'm not sure if this has been mentioned here, but FCP Euro does have a lifetime replacement policy.
I was looking for some uprated brake rotors/discs for my 2004 E55 Brabus K8. I want brake discs that do not get rusted easily, and possibly something lighter, but still bolt on with original calipers. I used google and searched here, but didnt find anything.
Finally went ahead and ordered from MTEC in Ireland, spoke with them on the phone and they gave good service. Price was good too.
https://www.mtecbrakes.com/brake-dis...11-08-02-08-06
Anyone tried these, or some other recommendations that I missed out on? I will update here after installation and give an assessment.
Rotors don't typically rust unless you haven't driven the vehicle in a while, and it's sitting in a climate that's conducive to producing rust after a few days. That happens to me sometimes when it's parked for several days after a rainy day, and it's humid. I can imagine that'll happen to any rotors, depending on the climate, but nothing to worry about.
Went that route along with Zimmerman's for the rear: https://www.fcpeuro.com/products/mer...g-2114231012oe
Thought about going with some EBC pads but didn't really want to do all the bedding in they required. I'll update with the pads I got once I see how the dust is.
I have the Brembo two-piece on my E63, and use the Pagid rear rotors. Rust corrosion isn’t an issue even after the car has sat for a week.
- Less unsprung mass. Always good for handling and ride.
- Less rotational inertia. Good for acceleration and braking.
- The two piece design is supposed to be better from a heat dissipation standpoint or....they are more warp resistant under heavy sustained use.
- Uh, they look cool?
- Maybe the disc is supposed to be separately replaceable from the hub to save on consumables for racing but I don't see any piece parts, only the whole rotor
But the question is do any of these theoretical benefits really show up in any non-track situations? As far as outright braking capability or initial bite, I wouldn't expect to notice much of a difference.
$450 for rotors, pads & all accessories needed for a front brake job.
then you have their lifetime replacement guarantee so your next brake pads & rotors are free and the ones after that and the ones after that.
So I weighed them, front is 15,65kg/34,5lbs, rear is 10,1kg/22,3lbs. This is same as stock weight, and its the heaviest rotors I have ever handled.
I had them painted from Mtec with their black protective coating.
I wish I knew before about the Brembo 2-piece option mentined above. I would assome some steering feedback benefits of a slightly lighter front rotor?
I looked a bit more and also found this link here to 2-piece rotors from Girodisc:
https://www.girodisc.com/Front-Rotor...MG_p_6512.html
They are 10,7kg/23,6lbs thats quite a good reduction in rotor weight, but at a cost of 1200 USD/pair. What is the weight of the Brembo 2-piece option?
I assume the Mtec brakes are essentially like stock rotors, will install tomorrow and let you know.
https://varuosatark.ee/parts/mercede...976423/BREMBO/
